Flaking favorite
  • Thread starter SailboatOwners.com
  • Start date
Thomas Ehmke
I second Rob. Printed and Saved that one, Rick!
Sometimes the best ideas are the simplest!!
F
Frank Arndorfer
Combination
I own a new H340 and single-hand quite a lot. The boat has Hunter's version of stack-pack and lazy jacks (all factory). I did wrestle a lot with snagging battens and it wouldn't come down real wasy, partially due to new (stiff) sails. I recently added/installed a Harken batcar system and VIOLA.!!! what a diference. Had an additional full batten added about 2/3 up. Because of the roached mainsail, Dutchman wasn't an option. Now I can raise the main manually without ever using a winch handle, reef on almost any point of sail, and when it's time for the main to come down, it drops so fast that you actually have to slow it with a few wraps around the winch. Because it comes down quickly it stays right on the boom and just some minor "dressing" when in the slip is all that's needed to wrap it up. VERY satisfied.
Jared D. Miles
EZJacks better than Dutchman
A year ago I sold my 1995 Catalina 270 which had the Dutchman System. It worked quite well, but I didn't like it flapping around while underway. So, when I bought my new 2000 Catalina 320 I deleted the Dutchman System and self-installed an "EZJAX" System. I love it. It's there when I need it, but gone underway, but stores underway.
Dr. R. A. Brown
Bunt stowing
My mainsail has been stowed using the "fold it into the bunt" method for a number of years, and it is still serviceable. Last year I won my class in the Dauphin Island Race with it. Many people flake the sail over the boom, but this has the disadvantage of the sail falling or blowing off in a heap just before the gaskets go on. In be bunt method you throw all the sail over one side of the boom. (I prefer the port side since I am right-handed.) Then pull about two feet of the sail back over the boom, and let it droop a little. This forms the bunt. Then reach over the boom and pull another two feet or so back, and let it fall into the bunt. Continue until most of the sail is stacked in the bunt. Then roll the bunt up until is sits on top of the boom, with the majority of the sail inside the roll. Finally, apply the gaskets. The method really works fine because the sail remains under complete control during the whole operation. Also, there is NO additional windage as with the other three methods using lazy jacks or their equivalent.
SailboatOwners.com
Final results
Final results for the Quick Quiz ending 2/11/2001: What's your favorite mainsail flaking system? 34% None 30% Lazy Jacks 26% Dutchman 09% Stack Pack-type system
