Varnishing teak is risky
Teak has natural oils and so to get varnish to stick to it with duration in mind you must properly prepare the surface.You need clean it properly, sand it smooth and use primers subcoats first. Some people use epoxy, thinned as a good base coat, but then you need to use a varnish that works with epoxies (some don't adhere well) and you have to clean the amine blush left on cured epoxy before applying varnish.One system that seems to work well is by Epihpanes. They have a varnish system designed for teak. Make sure you buy the right product. The thinner is mixed with their teak varnish in varying degrees or ratios starting with 50/50 and then adding more varnish as you go (read the labels for exact mixtures). Then you can apply, after you have that initial base as many coats as you like to achieve the level of gloss you want.It is for sure a labor of love and must be kept up to achieve this result over a long period of time.I would be careful using one type of product over another type as the most recent one can be too agressive to apply on an old application. It is good to know the compatibility of the product there already and what you are applying.Unless you are starting over and stripping it down to nothing, it is best to stick with the same product or a product similar in chemistry to what is already there.If you don't want to deal with the labor of varnishing teak properly, try other teak products like Sikkens Cetol or Armada, which look fine and are a ton easier to apply and maintain. And they last a long time as well.Varnishing is outstanding, however, as the results can make a beautiful boat beautiful.
