Fixed swim ladder to telescopic ladder
44
Hunter 336 Patchogue, NY
Wondering if anyone has replaced a fixed swim ladder with a telescopic one. My 336 ladder is fixed and in order to fold down transom seat and open walk thru, the ladder has to be in water. Prior boat was a 326 with telescopic ladder, which permitted me to keep transom seat down and walk thru open while underway. Any experiences and suggestions would be appreciated. - Dennis
Hunter 29.5 Gloucester, VA
I'm with you Dennis. My 29.5 has the same type ladder. We are looking for a solution same as you. Looking at some in the defender that telescope and pivot. Might have to fabricate or modify something.
May 24, 2004
7,228
CC 30 South Florida
Just a suggestion and take it for what is worth. If the ladder does not get much use consider removing it and storing it away for when you go sell the boat. A rope ladder which could attach to the swim platform handles could be stored in a stern lazarette for when needed. Just ask yourself if the use of the ladder is worth the cost and installation work for a permanent modification.
May 28, 2009
764
Hunter 376 Pensacola, FL
Several owners have made this modification. Rick on Whiskey Chaser can probably send you some pictures of his boat, which he modified to a telescoping ladder. The trick is making sure the width is correct so that the mounting brackets fit into the molded depressions in the swim step.
Aug 25, 2010
30
Hunter 376 Charlestown, MA
I am looking for the same solution for my 376. I have removed the ladder as I back in to step directly onto the dock, but I'd rather not have the ladder lashed to the rail when not in use.
