Fittings onto a new Vetus tank
Tim M
Oct 19, 2014
25
Hunter 37C Blaine,Wa.
Does anyone know: Is it a good idea to spread a thin coat of adhesive - e.g. PL5200 - on both sides of the tank when installing new Vetus fittings on a new Vetus flexible holding tank? Thanks for the input.
Tim
Dec 2, 1997
9,010
- - LIttle Rock
No it's not. But then, neither is a bladder tank a good idea for sewage holding. In fact, if it's an UNvented tank, it's not legal for sewage holding.
Tim M
Oct 19, 2014
25
Thanks for the advice Peggy. It will be vented, properly and legally installed. It's a quick solution to meet tankage requirements in order to move into a live-aboard marina. Hopefully it will see little use otherwise a larger main tank will be installed. From past experience bladder tanks usually fail because of poor installation, abrasion or fittings leaking at the tank. I just didn't want another one of those "I wish I would of..." moments somewhere down the road.
Dec 2, 1997
9,010
- - LIttle Rock
In your waters, I'd seriously consider installing a PuraSan Raritan Purasan EX It would all but eliminate your need to use the tank at all.
A followup answer to your first question: I wouldn't use any sealant at all....least of all, 5200. Teflon paste or tape should give your fittings a tight leakproof seal.
