I finished replacing the raw water pump last night. I switched from a Sherwood to an Oberdorfer. The Sherwood had (2) pretty heavy walled brass barbed elbows. Unfortunately it also used a ½ NPT to a 5/8 hose barb. The Oberdorfer comes with 3/8 NPT so I couldn’t use those fittings. I had a horrible time finding 90° elbows with 3/8 NPT to 5/8 barb. I finally found them at McMaster Carr but they appear to be a bit flimsy. The wall thickness isn’t what I hoped. The barb isn’t long enough for 2 hose clamps although the original Sherwood only had one hose clamp. Can anyone recommend a good source for fittings?
Thanks Bob
Thanks Bob
