Fishfinder vs Depth/Speed - Which do YOU use? RECOMMENDATIONS??
JVB
Jan 26, 2006
270
Schock Wavelength 24 Lake Murray, SC
My RayMarine displays speeds to 1/10th mph. I find that useful for docking and racing.
May 25, 2004
4
- - Peoria, IL
I am currently going back and forth between transom mount fishfinders and depth gauges.
In the order of most to least important, I would like to have a unit that displays:
1. Depth
2. Speed
3. Water temp
4. Fish
I also don't want to spend more than $250.
The fishfinder I am looking at is the Lowrance Mark-5X Pro, ($200) which has depth and water temp, but no speed indication. My problem with this fishfinder is that Lowrance has had mixed reviews and I am questioning the reliability. Also, without speed indication, I will have to rely on my Navionics GPS iphone app, which doesn't track speed until you reach 5mph- which is less than helpful.
The speed/depth gauge I am looking at is the Raymarine ST40 ($240) which is a reliable brand name, but doesn't show fish, contours of the ground, or water temp.
If you know of a unit that has all the features I need at a price that is under $250, please help!
I would also be interested in hearing about your experiences with fishfinders, depth gauges, and the top name brands.
Thank You!
I use an Eagle Fish Id Plus with the speed, distance, and water temp functions that I bought off eBay for under $200.00. I like it because I can compare speed over the bottom (GPS) to boatspeed to get arrive at the effects of the current.
May 25, 2004
4
- - Peoria, IL
Sumner
Jan 31, 2009
5,254
Do you know anything about the NMEA 183 input feature with it (Cuda 350-S/Map). Can you download waypoints to it?...
Well to answer my own question if anyone is interested. I called Eagle and the tech guy (seemed to know what he was talking about) said that you could not send waypoints to it from navigation software such as SeaClear II or Open CPN.
It will output the GPS position to say a computer with navigation software or a VHF with DSC (and I'm hoping both).
Also if you were using the NMEA data cable you then gave up accessories such as a speed or temp sensors. You would still have GPS speed SOG and would give up the option for a speed sensor that would give you STW. I think you would still have temp from the sonar transducer, but if it was in the boat you wouldn't have temp.
For us I think it is still a good deal. I'd mount it shooting thru the hull, so I'll have to tie a thermometer on a string and throw it overboard for water temp :). If I can wire it to the VHF with DSC and to the computer/chartplotter it will eliminate having to run a gps puck and another gps for the VHF. Also we shouldn't need to use one of our handheld Map76's in the cockpit unless we want to download a complicated route with a number of waypoints from the SeaClear.
So it will give us GPS position in the cockpit, along with a GPS signal for the computer and VHF. Also speed and depth and all from just one device that Ruth will be able to see easily from her position on the tiller. For route planning we will have the chartplotter and paper charts in the cabin.
Not as nice as some of the more expensive cockpit chartplotters, but I think it will handle our needs nicely,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
Jun 7, 2007
875
Pearson- 323- Mobile,Al
Temperature, I doubt that the temperature inside a hull is much different than the temperature outside the hull. Fiberglass is not a very good insulator. I noticed that the temperature indicated by my fish finder changed during the day and was colder in the river than in the bay. I did not compare the displayed temperature to a thermometer immersed directly in the water.
Sumner
Jan 31, 2009
5,254
So you can see if it is warm enough to jump in without freezing.
Yep, I need to see if I need the wet suit on or not :). Just had to use the suit once so far.....
http://purplesagetradingpost.com/sumner/MacgregorTrips-3-Powell09/09-10-8-Powell-09.html
...but glad I had it. After that experience I now have a marker float on the anchor all the time.
Also on the temp I guess it is just human nature to want to know what it is or we wouldn't have them on the side of the house and inside and look at the bank temp sign, etc., etc.....
Like I said a thermometer on a string overboard will work for us ;),
Sum
Our Mac Pages
Mac Links
Ross
Jun 15, 2004
14,693
There is much that we don't need to know but enjoy knowing anyway. How old are you? How much rain did we get last night? How hot it is it outside? What's for supper? There isn't anything we can change about any of this but we still like to know.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
If you're sailing in the Atlantic, it can also tell you when you've crossed into and out of the Gulf Stream, since the water will often be warmer when you enter the Gulf Stream and cooler otherwise.
Other than for fishing, what's the deal with temp? Just asking.
Rich
Apr 1, 2010
398
Cal 33 and Sea Pearl 21 . Crystal River, FL
In regards to the temp being the same inside the hull vs the water. that is not true. You will notice trends (like indicated above with the gulf stream). You will see the temp rise and cool but the number is not accurate. I have the transducer of my cuda 250 shooting through the hull of my kayak (1/8" plastic) and the temp is off. Also, it takes a solid hour for the temp to level out after putting the yak in the water. If you leave your boat in the water Im sure it will be a little more accurate but there is still quite a delay.
Ross
Jun 15, 2004
14,693
If there is a large difference between the air temperature and the water temperature then an inside transducers will read something that represents some average of the two temperatures.
Jun 7, 2007
875
I know that back during the winter the inside of my sailboat stayed about the same temperature as the water especially down in the bilge. Below freezing outside but warm enough inside. But I agree that there probably is some small difference. As to temperature it was an unexpected bonus on my fishfinder. Coming down the river I thought that shooting through the hull reduced sensitivity so that I could not see fish. But once I was in the bay I started seeing fish!!!! It may have something with saltwater being more dense.
Hunter 36_80-82 Halifax Nova Scotia
no comparison
the advantage of having a finder over a depth gage is that it lets you know what type of bottom is underneath you , is it rock ,sand ,gravel ,or whatever and it will still show you fish . A depth gage will only show you depth and there`s all kinds on finders on the market for under $200.00 that are really good .
jfmid
Jan 31, 2010
152
Oday 27 LE Manahawkin, NJ
If you are going to get that and shoot thru the hull you will most likely loose the temp (you will know the temp inside the bottom of the boat). Some of those will allow you to buy a second temp gauge.
That has a nice display, but for us we aren't fishing, so that is a minor consideration in the purchase. Just my feelings, but I think the Cuda 350 has that one beat if you aren't that interested in fishing.
The best though,
Sum
How is the Cuda 350 mounted. Is it through the hull and if so how is that done??? I'm interested in this but dont want to go punching holes in the hull just yet.
Oct 22, 2006
35
O DAY 27 LE philadelphia pa
I set my transducer on the inside of the hull. I set it in a plumber's wax ring. I got a wax ring from HD and shaped it with my hands into a fat pancake. I then pressed it onto the inside of the hull making sure that there weren't any air bubbles in the wax. It stuck well, it has been in the same location for over a year without any problem. I then pressed the transducer into the wax and the job was complete. The pictures that I see on the screen are clear without any problem. It doesn't sound like it would work but it works great.
Sumner
Jan 31, 2009
5,254
jfmid
Jan 31, 2010
152
It sounds so simple and easy. I'm used to things being way more difficult to finish than they seemed at the start. This is great to hear. I have a sand bar to clear at the entrance to our creek/lagoon which would almost ground us at max low tide. This will be a great help on the Barnegat bay, NJ which is notorious for sandbars and shoals especially in the southern half. Thanks guys.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
On the other hand
If you sail in water with currents, you really should have both SOG and STW.
A nice hand bearing compass will do the same thing for SOG if you are near land. Just plot your position over a fixed period of time and compare the two positions on the chart with a set of dividers and you easily get speed over ground. A Davis HBC is maybe 25 bucks.
Not sure what you have for currents in San Fran bay but up in Long Island sound I've sailed at 5 knots and watched the same house on the shore in exactly the same bearing to my boat for over an hour.
Speed is an extremely important piece of information when you are dead reckoning in pea soup fog. Without it you don't have any idea where you are.
