Regardless, it's totally doubtful that a mainsail alone can perform this stop the boat maneuver.
From
http://www.ericsonyachts.org/infoex...ng-to-with-main-sail-only&p=106666#post106666
The post reads:
We heave to regularly out here in French Polynesia in a wide range of conditions as we must often wait for the correct tide or light to enter the atolls. After much trial and error we find reefing under main only is our preferred method for our E38-200. To address Christian’s comment about not seeing the benefit of main-only versus heaving to with backed jib the benefits include considerably less chafe, more simple maneuver (assuming you will need to partially furl a genoa prior to backing it), far less leeway, better “motion” of the boat, and especially a much better angle after the boat settles in relation to the wind. We find our E38 hove to with a backed jib sits with the bows too far off the wind, almost beam-to in heavier wind/seas, even as she does the typical “scallop” path. In rough conditions we find that heaving to under deeply reefed main only (or even better under trysail) more or less “parks” our E38 with the bow about 40-45 degrees off the wind thus presenting the strongest/safest part of the deck to the weather (the forward corner of the cabin) and allowing a more of a gentle “pitching” motion instead of a roll. Most importantly it places the all-important “slick” in a better position to knock down seas (as well described in the Pardey’s excellent book “Storm Tactics”).
The move is simple. Just gently turn into the wind as you trim your main to about the position it would be for a close reach (remember to reef it first). The main will luff and your speed with drop. At some point you will have no forward momentum and the bow will gently drop off to one side. At that point turn the helm as though you were trying to turn into the wind and lash it in place (we use the wheel brake and a sail tie lead to the cleat near the primary winches.) If you timed it right the boat will gently bear away until the main starts to fill then gently turn up as the center of effort shifts aft (with the partially filled main) and the slight forward motion engages the rudder. This causes the main to luff and your speed to drop which causes the bow to bear away and so on. When you get it “right” the boat balances well and there is not much heading up/bearing away unless waves move you around. You can easily see the “slick” caused by your boat sliding sideways. Ideally you want that slick between you and the oncoming seas.
Be careful about going completely head-to-weather to stop your progress in rough seas as they can push you back and put tremendous loads on your rudder, especially if it’s turned to the side. It’s enough to pinch into the wind to slow to the point that the bow falls off and you will not tack when you turn the helm hard over.
In calm seas and gentle winds we sometimes even heave to under bare poles…
I hope this helps!
Ryan
SV Naoma
TwoAfloat.com
