First time boat owner seeks advice
Sep 23, 2009
1,475
First boat is always more intimidating. You keeping asking yourself do I really want to get into this unknown.
Do your homework, run the numbers against your monthly budget and then run the numbers again. Get the survey.
Plan the time, work, family, recreation, plan it well. If it clicks after this, go for it, you only live once.
What he said!!
Sep 23, 2009
1,475
Not that hard. Get a sanding pole with some brown scotch bright pad to rub the old paint well then roll on two coats of anti foul paint. Should only take a few hours.
A boat is a commitment but "nothing is so worthwhile as messing about in boats".
Enjoy the learning curve.
May 16, 2011
140
Oday 28 Niceville, FL
One thing I will say. My sailboat is less of a money pit than any personal watercraft or power boat that I've had. The other thing is its always a family affair. While I'm the mechanical one in the family, my wife is always good with cleaning up the messes I'm making while working. My 13 year old son is learning and has become my mast monkey, while being a small enough build to get into places I can get into but have difficulty getting my tubby butt out of. Even my 10 year old gets in on things. He's small, great and squeezing into small areas so he can hand me tools, screws, nuts, bolts etc. There is always something that needs to be done.
The most enjoyable anniversary trip I had in 16 years of marriage was on that boat :) Panta Rei is dead on, its an investment in time and money, but the return is worth it in my opinion. Just make sure you don't have anything major wrong with the boat. Sounds like you are getting a deal (dock fees?) because they want to be done with it?
As an aside, I'm also happy to provide shots of any modifications I've made to my boat. A lot had been done to it before I got it and I've done alot to it afterward and still going. Running joke in my Marina is that I've got the most ridiculously over equipped 28 in the marina. Personally I think the guys in the 34 plus boats are just jealous that I have AC and heat :)
Sep 23, 2009
1,475
Could be the fixed portlights are leaking and the water is running through and down the decks. They are replaceable, I just did mine and there are links to fixed portlight repair on this site.
So long as the decks are firm a leak is not the end of the world. O'Day was one of the few builders to use marine plywood and not balsa in its decks.
About the only likely money pit on an O'Day might be an engine so look carefully at that and if ok, you have found a great starter boat.
BTY, brand new boats need mantianence too.
Coyote
Sep 30, 2008
132
Hunter 30T Madeira Beach, Florida
Hey JVelky:
Did you eventually buy the Oday 28????
let us know,
cheers,
Coyote
