First Solo Sail!
Ward H
Nov 7, 2011
3,833
Weather report for today was sun and 5 to 8 mph winds. Sounded like a good day for my first sail in my Newport 17. I had motored in it once but this would be my first time sailing it.
Now, I should point out that I am 58 and 230lbs. Not in the best of shape.
Got to the lake, went to raise the mast. Where was the hinge pin? There it was, in the bottom of the boat. Forgot to put it back in last week when I practiced putting up the mast. At least it dropped in the boat and not on the road. Put up the boom and hanked on the jib. Using the jib halyard to help raise the mast worked well. So did the new topping lift for the boom.
Hung the outboard and tried to plug in the line from the portable tank. Gas sprayed every! Over the motor, back of boat and my arms. Whoops, forget to let off the tank pressure.
Cleaned up that mess and backed down the ramp. Got the boat off the trailer and tied to the dock. Put the truck away and went on the boat to get out cushions and make ready to sail.
"What's that water doing in the bottom of the boat?" By the time I found the drain plug and pulled the stern over to the ramp where I could reach down and install it, I had 2 - 3" of water in the bilge. Do I go get the trailer and pull it out to drain? By now four bass boats were lining up for dock space. Decided I could pump it out if needed while out on the lake.
Motored out to the middle of the lake, headed into the wind and raised the mainsail. Whoops. It was tangled. Brought it back down, straightened the boltrope and tried again. Still tangled! Got that straightened and raised it again. Now tangled in the spreaders.
Finally got the mainsail up. Shut down the outboard and tried to raise it. Didn't have the strength! (The motor bracket will be the subject of another thread)
Oh well, I was finally moving under sail. Time to raise the jib. I was so beat all I could do was sail on a beam reach under the mainsail. The jib just would add more work so that could wait also.
After about half an hour I got my breath back, my chest stopped hurting and I was ready for more action so I raised the jib. This was more like it. I was tacking back and forth across the lake for about 1 1/2 hours. Boat didn't handle that well due to the water in the bilge and the motor being down but I was sailing and finally relaxing a bit. Glad I had the windex because the wind was shifty. Wait a minute. It's not moving. Got stuck. OK, I can watch the water for the wind.
Felt good, got used to heeling 15 degrees and moving pretty good! Lost the wind after a bit so I decided to douse the sails and motor back. Dousing line for the jib worked well. No sail ties so mainsail was in the way but I worked around it.
With the extra water the boat was sitting lower in the water and tougher to get back on the trailer. Drove up off the ramp and out of the way so I could stow away the sails, mast, so forth. Pulled the drain plug and drained the water. Boy was I beat. Took awhile but finally had everything stowed. Boy, the boat was sitting crooked. Decided to back down the ramp, float it and line it up better. No problem now the water was gone. Pulled it up the ramp a bit and stopped to put on the waist strap.
"Excuse me, Sir! Can I see your ramp permit?" Turned around to find the DFW officer was talking to me. Sign, what sign? Oh that big one over there. He took my license, instructed that it was ramp ettique not to work on boat on the ramp. I was too winded to try to explain anything so I followed instructions to meet him in the parking lot.
He advised me that DFW violations mandated court appearance and fines could run up to $1500. He took pity on me and told me to get my permit and fax it to him within a week and he wouldn't write it up. We talked a bit, he looked over my trailer and hitch set up and sent me on my way.
Glad I took the suggestion from this forum and left the Admiral home for my first sail. Might have been her last!
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
I don't have one of those degree of heel gauges. Not until she gets used to going over on the side.
Joe
Jun 1, 2004
8,323
Well, that's out of the way.... next time will find yourself doing the following:
Rig the boat in the parking lot...... install drain plug.... there isn't one person here who hasn't forgot to do that.
An empty coffe can makes a good bailing scoop.... put one in the lazerette.
Put the sails up at the dock or on the beach.... much easier than trying to hoist the sails and control the boat at the same time.... try sailing off the dock if possible. The less you rely on the motor the safer you'll feel.
Spend as little time on the ramp as possible. Attach the bow strap and winch it up, pull the plug.. then pull the boat out of the way .
Install "telltales" on your sails. ....life will be good. Here's a link: http://www.arvelgentry.com/Telling_tales.htm More important than a windex.
Heeling is not fast on a centerboarder.... keep it flat.
Acquire a handheld gps.... Garmin 76 is good. No need for a chartplotter just the gps... it'll tell you how fast you're going and what direction.... you can mark important waypoints on the lake. Like the marina entrance, shallow water, obstacles etc....You can also use the VMG (velocity made good) feature to steer the most effecient course towards your destination.
Keep practicing... keep the boat flat... it will make your wife happy. Don't forget to let her steer....she'll love it.
Aug 2, 2005
1,155
Hello Ward,
I was thinking that having an additional person would have been helpful, but as you said it might have been her last trip to the ramp. As already mentioned we all have had those problems (or we are lieing). Each of those situations handled will be in your set of skills so they can be avoided or prepared for in the future. I think that is called "learning to sail". At some time in the future you will be able to recount those actions with a smile on your face.
Best wishes for continued enjoyment of your sailboat.
zeehag
Mar 26, 2009
3,198
and folks think sailing isnt work...lol goood work--ye learned a lot. congratulations.
weinie
Sep 6, 2010
1,297
Um, might wanna see a cardiologoist bout those "chest pains"?
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Ward,
Everything you reported is all too familiar, including forgetting the drain plug. Setting up, going for a sail and then breaking down a daysailer is hard work. The good news is that you will get better at it so that it is less tiring and goes more quickly.
I'm not sure if the 'dry sailing' option is available on your lake. Dry sailing is when you setup your mast and boom and leave the boat and trailer at a location at the lake near the launch ramp. This way you only have to step or un-step the mast when you want to take the boat home or another lake. It also reduces setup and breakdown time resulting in more (hopefully) relaxing sailing time. With 'dry sailing' you would likely have to pay something to store the boat in a location near the ramp where there are no low lying power lines.
Good report. You did great, really!
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
Where did you sail?
It sounds you got a break with the DFW, but it begs the question ... How did you get to the ramp without first paying for the use of it? You must have been at a reservoir that is frequented mostly by fishermen, but I can only think of a few that allow gas engines .... Round Valley or Spruce Run?
Spruce Run has a dry storage area, Round Valley does not. Lee's Park on Lake Hopatcong has a big area for dry storage but it is probably filled for the season by now. I would guess that Spruce Run is filled, too, as it usually requires that you be on a waiting list due to the demand. Other than the coastal areas, lake sailing in New Jersey is VERY limited.
Hot days like today are brutal for set-up and break-down for every day sail. It really makes a difference to find a place to keep the boat in the water or at least dry storage with the mast up.
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
Scott is right on. The easier it is to go saiing, the more you will go.
Ward H
Nov 7, 2011
3,833
Scott, I was at Union Lake in Millville NJ. Something like 898 acres of water. Was owned by a manufacturing company for quite a while. They had used water from it for hydro power. The DFW took over in 82. There is a city owned ramped but it has been years since I windsurfed from it. The DFW took over and put a ramp and parking lot in on the other side on state owned land. Parking lot will hold 50 trailer rigs and has a nice finger pier. Winds can be shifty but it is the largest fresh water lake in South Jersey.
I have windsurfed both Spruce Run and Round Valley but that is too far for me now a days.
My real reason for getting the boat was when we are on vacation in LBI. We rent a house with a dock on a lagoon, about 300 yards from the bay, twice a year.
So, for now, sailing at Union Lake is just practice. If we find we really love sailing, we got several options. Trailering it to the lake, joining the Union Lake Sailing Club and getting a mooring or saving that money for sail boat rentals on Barnegat Bay. Renting a 23' Catalina might be the way to go for the number of days we might get out sailing in a summer. Plus it gets us into a nicer and bigger boat. Where I took the ASA 101 class, they have a buddy list where you can send out a mass e-mail looking for people to share a days rental with. That would help to keep the cost down.
I am glad to hear confirmation that my day was just part of the learning experiance. On the bright side a lot of things did go right on Sat. My new rigging worked well. Using the jib halyard to hold the mast up while connecting the forestay made that job a lot easier. New boom lift worked well. Jib downhaul worked well. Rudder repair held up.
Won't forget to relieve the pressure on the gas can again. :) Plan to put the drain plug on a lanyard and loop it around the main sheet traveler so it is in plain site as a reminder. Got to get some sail ties to tie it up when not in use. So far I have been using the mainsail sheet line when tying the sail to the boom for the storage.
I'm already looking for my next day of sailing.
As for the chest pains, that's been checked out before. Just got winded.
Thanks for your support, much appreciated.
Oct 21, 2011
109
O Day Mariner 2+2 my driveway/ Lake Wallenpalpac
Gee, this sounds like my first solo sailing!
I thought I knew how to sail after taking the ASA 103 course!
Bought my first boat, took it to a small lake launched it, thne it all went terrible wrong!!!
I was SO nervous my first time, I forgot to drop the keel and spent an hour doing 360's (well before I ran aground and had to climb outta the boat to get her off the rocks!
I swore I couldn't "do this", that a made a very bad mistake, and thought I better get back into motorcycle racing!
Second time was better and at the end of last season, I had the setup and tear down to a science.
Hang in there, this is the steep learning curve they talk about!
I'd get those chest pains checked!
Be a hell of a thing to try to tear down you boat whilist having a massive heart attack!
Joe
There is just SOMETHING about when you turn the motor off, raise the sails and they fill with wind and.............. your SAILING! that just makes me grin ear to ear! :)
Jul 18, 2009
274
marine clipper 21 ft santa ana Southern Lakes,Yukon
Ward....have ya thought about a tv reality show when your sailing..??...dang it would be something...lol..
