25.5
The attached link is to copies of the original 25.5 manual. It's not as useful as it could be, but does supply some information.My fuses and switches are located immediately below the cabin entry, but expect mine is not normal. Access to fresh water is at the bottom of the starboard lazaret where a plastic inspection/clean out plate is installed. I flush my water system periodically with a bleach/water mixture that I place in the tank, run the pumps until the water from the tap smells of chlorine, sail around a little to slosh the mixture in the water tank, empty the tank through the sinks, and fill the tank followed by running water until the chlorine smell is gone. Discussions of "shocking" the water system this way can be found in the forum archives. That process seems to work, but the water never seems quite "fresh". Use it mainly for washing dishes, hands, and water for cleaning spills.My pumps (2) are located under the floor of the stearn bed. Both are electric and need to have a good prime to work. They pump when the switch at the individual sink is thrown only. They do periodically get air bubbles in the lines and stop pumping water. I have to fiddle with the lines to get the air out of them (or at least past the pumps).Don't have either a bilge pump (other than manual) or a head (other than porta potty)
