rochesterdriver
I like the one rochester has and I have a 12volt pump type also which I like with a see clear container that I use and like it very much but to each his own and just make sure the engine is warm so the oil passes through the small tube and I push the tube down into the dip stick so it gets the bottom of oil pan,omce some thing I did wrong and not all the oil came out.
Nick
