OK so I have owned many powerboats throughout my life but got tired of them and have always loved sailboats so I bought a 1985 O'Day 26 this last May and decided not to launch but to rebuild/repair EVERYTHING (my wife always tells me I am way to much of a perfectionist). Below is a list of what I have done so far and I have many other things to do before winter and early next spring. As I sit at night, I try to think....what am I missing and then it hit me...I need to ask experienced sailers what I am missing and what are the top 10 things I should make sure to do either before launch or right after launch and before that first sailing adventure.
No I haven't taken the ASA 101 class nor do I really have the time (a week and 2 1/2 hours away). I have read 3 sailing books twice now and will probably read them again over the winter. I am not really worried about learning to sail but more of getting into trouble quickly. I purchased a 36 foot slip on Lake Huron as well and hope to find an experienced sailer there to go with me and/or a old family friend who taught sailing at the local college (Michigan State University--GO SPARTANS) who still owns 2 sailboats. After reading what I have done you can see that even though it is nice, none of it except maybe the thru hulls have really nothing to do with the safety of sailing. I need to check standing rigging yet and have never done that and hear about this so called tension tool. Still have to also learn how to raise the mast and get the CDI roller furling set up correctly.
So with all of this, what do you think are the top 10 or even 5 things I better do before my first launch or sail next May?
Items complete:
all new electric including lights (to LED) and fuse panels
remove and rebed mast tabernacle
all new fresh water lines and drains and added drain valve near water tank
installed 4 drink holders in cockpit
installed exterior speaker in cockpit from ship-to-shore radio
installed Whale Gusher bilge and hose out starboard side
pulled and resealed port lights and installed new windows
new acrylic tinted hatch boards
new foward hatch
scrubbed deck
new teak hatch rails
refinished all other teaks (removed, scraped, stained and clear coats--Cetol)
installed LED masthead light
complete new sanitation system including head & hoses
installed battery meter in cabin
replaced all 3 thru hulls (1 1/2" dump capped and wired shut)
NSF hull, compounded and finish paste
replaced entire rub rail
repaired depth finder cables
repaired ship-to-shore radio antenna wire
relocated ship-to-shore and AM/FM (bluetooth) radios
secured all shore power wires and encased in raceways
rerouted speaker wires and in raceways
stripped, sanded and repainted outboard motor cover
replaced outboard sparkplugs, oil and lower unit oil
teak oiled all wood in cabin
covered interior speakers and depth finder with white cones
added anti slip strips to companionway steps
installed 2 blue LED cockpit lights (for those nights drinking Corona)
routed galley cooler drain from bilge to galley sink drain with isolation valve
cleaned all storage areas with Acytone
Items left to do:
wax entire hull
pull and reseal tinted main cabin windows
replace chain plates
build gin pole and mast raising system
remove outboard wedge, replace with Starboard and new Garelick mount
replace all lines (sheets)
*many other small items as well (which I lived south so I could work all winter)
Items complete:
new foward hatch
scrubbed deck
Items left to do:
wax entire hull
