Sorry Guys
>>>>> But Steve is wrong on this one. To start, Diesel engines DO NOT run hotter than Gas. They run at the same nominal, thermostat regulated 160 or so degrees. While momentary internal burning temp may be higher in a diesel (although I don't remember it being so) the cylinders on both are cooled by incoming air charge. The difference? Diesel is unthrottled and always, ALWAYS pulls in a FULL charge of cooling air. To proove it to yourself, on the next 10 degree below zero day run your engine up to operating temp (under load) and then let it idle. You WILL NOT be able to keep it up at operating temp.Yanmar's current recommendation for the engines; "GM" series is 15W40. For internal lubrication there is simply nothing better. The additive package that makes it a multi grade enhances viscosity and lubricity at operating temperature. ie: it has the lubricating characteristics of a 40 weight oil, but cold flow characteristics of a light viscosity oil. (Faster starting due to less oil induced drag) Simply, as the oil gets hotter, it works better. You'll never see me using a single grade oil in the engine. The trans is a different story. It doesn't need the enhanced characteristics. it just needs the slipperyness and CUSHIONING effect of a gloppy single weight.Oil filters? HUMBUG!! (I've always wanted to say that!) Consumer's Reports years ago proved that the manufacturer's filters were the worst. Fram, Hastings, NAPA and the lot were all better filters. As far as the "valve" is concerned, it's just a check valve to keep the filter full of oik when the engine is shut down. If you pre-lube before starting it's a moot point. A friend of mine hack-sawed a Yanmar and a NAPA filter apart and internaly they were IDENTICAL. Yanmar and their dealers are a conservative lot and want you to buy their parts. I know; I worked for a distributor some years ago. Bottom line? Change oil and filter at least once a season. Use just about any name brand oil ( I've always been partial to and had good results with Castrol. About a buck a can on sale at K-Mart.) with the latest API classification rating (CC, CD, CF, or whatever it's up to by now) and you'll do fine.
