Scott
Last night I was attempting to fish a wire thru a bulkhead and past the electrical panel to get to the battery. It's the yellow wire from the new stereo I'm installing that wants to be connected directly to the battery for some memory function. I had the selector switch on because I had been "testing" some terminals on the panel.So when a stray red positive lead brushed up against the negative bar, the fireworks started and gave me quite a surprise! Fortunately, I was right next to the selector switch and shut it off before a fire started! The smoke was a little scary, though, and I was a little shaken up. As it turns out, it appears to be a 14 AWG positive lead that ran from a post on the selector switch directly to the battery display guage on my electrical panel. The end of the lead was the female end of a spade connector and in the tangle of wires I hadn't noticed that it was disconnected. The insulation of the wire was fried for the entire length.At first, I was puzzled because I couldn't figure out where this lead had come from until I noticed the empty spade connectors at the display guage. It was scary to realize that this may have been disconnected for a while!After I removed the wire, I turned the selector switch on and all was well. I am a little worried because after the excitement and the clean-up, I haven't inspected the wires that were in the same vicinity to see if there was any insulation damage to any of them. The negative lead, where the short occurred, does not appear to have any damage. I always turn the selector switch off when I leave the boat.I am a beginner at electrical work, but reading and learning with some new experiences. My panel has fuses (8 fuses and 8 switches), and the power lead ties to the first fuse in the series. There is no fuse at the battery display guage. The leads from the switches go across to a positive bar, just above the negative bar with all the various wires being attached with ring terminals at the bars. The terminals at the switches are spade. I imaging this is typical for older boats. Trying to get these wires organized neatly is going to be a job and a half, but I'm more nervous about not doing it now than I was before. Now it looks like a priority. Should I be worried about any leads that were in proximity to the fried lead?
