Fire/smoke/CO2 alarms
Feb 16, 2021
398
Hunter Legend 35.5 Bellingham
Has anyone found good smoke/fire/co2 alarms to use onboard? The FirstAlert ones we have keep going off randomly, sometimes in the middle of the night. Maybe due to humidity?
PNWE36
Nov 1, 2022
40
Hunter 36e Thunderbird W. Vancouver, BC
For CO alarms our e36 had wired in alarms. The attached pic shows the replacements we found. Marine approved and work well. No issues or false alarms. One is installed in the salon near the Nav station, the other is in the aft cabin.
colemj
Jul 13, 2004
492
Do you have lead acid batteries? Or stored solvents? Are the alarms near them? Outgassing batteries and solvents will cause false CO alarms. I don't think humidity plays a part unless it is actually steam in the air.
Otherwise, I think we have the same combined units as you do, and don't get false alarms (no lead acid batteries and solvents all stored outside living space).
Mark
  • Helpful
4,890
Pearson 37 Lusby MD
I installed a Fireboy-Xintex CO Alarm several years ago. No issues with false alarms like I had with a unit from a big box store.
Do t they always go off at night? At this point I think they are engineered to have the low battery alarm only go off in the middle of the night.
There’s a reason for that - temperatures at night tend to be slightly lower than during the day. Lower temperatures bring the battery voltages down slightly. As the batteries weaken they go past the low voltage threshold in those lowered temperatures first.
That sounds all to logical.
Personally I think it is evil demons in the unit that drain the battery so that it wakes the neighbohood and usually the babies
at 0:00 Dark-Thirty. Parents get no rest and are challenged to do good while they are feeling sleep deprived. :yikes:
We have the Firebox/Xintrex CO detector and so far no problems with nuisance alarms. The generic Smoke Detector works well and lets us know when we're frying something on the stove.
Apr 8, 2010
2,093
Just looked up the SafeTAlert line and foudn this site.
We have the 65 Series detector. No problems with false alarms. One caveat: many (all?) of these devices have a sensor in them that is supposed to be replaced every 7 years or so. Since the insurers require these devices, it is a recurring expense for us and a revenue stream for the alarm makers. (IMHO)
It's a shame they were not designed such that a new sensor cannot be easily swapped in.
Oh... Well.... :(
398
Mark
Lead acid batteries, but stored outside in the aft cockpit locker, so likely not the issue. No solvents onboard.
colemj
Jul 13, 2004
492
When our batteries are low, the units chirp every so often, but not go off in alarm mode. However, that chirping does always seem to be in the middle of the night.
Mark
