fire extinguishers???
643
SCHOCK santana27' lake pleasant,az
i have 2 10# abc type units that dont say anything about marine or cg aproval should i keep or exchange them. whats the diff from a bc and abc other than the obvious???
Catalina 320 Dana Point
If they have metal heads they can probably
be recharged by an extinguisher company if you have doubts about their age. Extinguishers with plastic heads are pretty much considered disposable. Only difference in a "marine" extinguisher is that the band on the wall mount is supposed to be metal not plastic (or vice versa). For CG Safety inspections I've only had them check the gauge, never seem to look close enough to see if CG approved. As long as it has UL (Underwriters Labs) and/or FM (Factory Mutual) approval it's probably OK.
Dec 2, 2003
392
Catalina 350 Seattle
bc vs abc
The designations "ABC" and "BC" refer to the type of fire that the extinguisher is designed to deal with. From memory, "B" is liquid fueled - such as grease or gas, "C" is electrical, and "A" is paper/wood/rags. Good Luck! Tim Brogan April IV C350 #68 Seattle
