Jim on Whiskey Girl, 1973 C-27
I've spent way too much time redoing the varnish from bare wood, and am down to the last coats. But I need some advice. How do you get the final coats on without air bubbles? I've read both Dan Casey's advice, and Rebecca Wittman's Brightwork Companion, and while they mention air bubbles, they don't really say how to not get them other then don't shake or stir. I notice that they get into my working pot from cleaning off the tipping side of the brush, or on the surface from putting too much pressure on the brush as I try to flow the varnish on, so I try to avoid both. Does anyone know of an additive that reduces surface tension, or have you tried to make the last couple of coats with the varnish cut with some mineral spirits? All advice welcome.
