I'm finally starting the replacement of the soles in my H31. I'll be using plain marine plywood, stained (water or alcohol based) to approximately the color of teak, then encased in multiple coats of West Systems epoxy on all sides and edges. I'm willing to install them at that point and be done, but I suspect (as do the folks at West Systems) that the epoxy will be slippery.
So, what do I use for topcoating that wont be slippery? The admiral likely won't allow paint (though I will check again). Research through the archives indicates that many of the best options (Ultimate Sole, Gymseal, etc) are no longer made.
1) Is there a currently available product, that can be applied over epoxy, that will not be slippery?
2) If I have to add something to a finish as a non-skid, what do you suggest? (I've read about using ground walnut shell powder.)
