Re vents
I do not have the vents on my 79 Cat 30 but there is a hole in the top of the tank caps. If I fill the water to the top some spills out, but its not a big deal. I will have to hook up a vent in the future to keep everthing dry if they are real full and we are healing over hard. The water goes in easy and if I fill below the full mark not much of a prob. You should have a hole in the top of the tank cap. Maybe unhook your vent if you have one, then see how the tank fills. If it fills ok. Go ahead a check those vent lines further for blockage.
