Filling in small holes in teak
1,438
Oday 25 pittsburgh
Brian, As a carpenter, patches are patches.
If you want it to look good, make it look like it was made like that. One other option, I will try to explain it. The thing that gives patches away are texture and color. If you take a razor knife and cut a diamond shaped cut that includes the screw hole, remove the cut area. (the cut should focus on the back point of the diamond that is at most 1/4" on each leg and only be about 1/8th inch deep.) Then from a portion of good material that is inside a cabinet or behind a bunk make the same cut. The important portion is the part that shows. You can trim off the back side of your patch until it fits. then carefully glue it in place making sure to clean off all excess. This is one way carpenters used to hide finish nails. I hope that makes sense! r.w.landau Edited: this works great if refinishing. it may not work well if you and just trying to do a patch.
Jun 2, 2004
1,438
Oday 25 pittsburgh
Ross
Jun 15, 2004
14,693
As the adage says there is more than one way
to skin a cat but most will make you sick. Try several methods on some scrap and decide which ones work best.
Ross
Jun 15, 2004
14,693
Dec 25, 2000
5,904
Hi Brian, I've been using an oil base teak putty...
for a few years on our boat and have been happy with the results. It blends and bonds well, accepts the occasional stain that I apply and dries hard. The PO left a small gouge on one of the companion way steps that I filled with this putty. Still there today and looks almost like the solid teak wood material. Every year or so I add a small amount of paint thinner to keep it soft and pliable. I do not recall the brand, but most building material stores will carry quality products for you to choose from. I think I got mine from HD. Terry
Dec 25, 2000
5,904
Jun 1, 2005
772
Pearson 303 Robinhood, ME
Teak...
sawdust and wood glue mixture. It however will not take a stain... but yet again... why WOOD you want to stain it?
Jun 1, 2005
772
Teak...
