Hi all
I'm figuring out the wiring order and design of the existing Raymarine kit on our 1994 Beneteau.
At the cockpit end, one Seatalk 1 cable (with the older ST-50 round three-pin connector) arrives and is plugged into the Autohelm controller. I assume this comes from the course computer (labelled Z121) but I can't tell for sure where because that's currently under some stowed sails.
From the Autohelm controller, another round three-pin into three spade terminals, into the slightly more recent Seatalk 1 connector (the three spades in a slightly curved row), on the ST-60+ speed unit. After that, the Seatalk connectors go Speed > Depth > Windex. The Windex second Seatalk connector is empty.
Back in the navigation station there is a NavData Z146 which is powered by another, older circular Seatalk connector. The second Seatalk there is empty. This Z146 has a broken display and is long left disconnected. It has a 2-pin input from an old GPS Transducer, also out of service these days.
So I THINK but don't know that the connectors are/were:
Spare Seatalk > NavData Z146 > Course Computer > Autohelm > Speed > Depth > Windex > spare Seatalk.
Does that model of course computer have two Seatalk connectors and does my assumption look correct? If so, should I be able to connect the Seatalkng converter into the cable that used to feed the Z146 and continue from there?
cheers
Simon
cheers
Simon
