Rick
Hey gangI was doing some spring cleaning in swimbridge locker and noticed a small leak. It is where my raw water exhaust connects to the below water exhaust port. It appears to be a plastic tube... pipe that is set into the hull. Upon inspection, the tube is cracked where you hook up the hose. No thru hull here. So it drips when I cut on the engine. I cant get the hoseclamp to tighten down enough to stop leak. Not bad but enough to repair. So can I epoxe the crack.. or glass it. Who has delt with this. Its a hunter 336.ThanksRick
