feathering propeller
Hunter 37 C sloop Punta Gorda FL
Gonna pull our boat soon for fresh bottom paint. Want a 3 blade feathering prop. Wanted an auto prop, but they only want to sell me 18" dia. Can't mount any more than 15''.
Will have to set at square or over square (15" pitch or more). I have a
2.46:1 tranny, 1200 shaft rpm at 3000 engine rpm. Current 15X13 red lines easily doesn't ever get to hull speed.
Had a max prop in the '80's. Lots more choices today. Anybody have any favorites?
Nov 28, 2009
495
Catalina 30 St. Croix
I've had Max prop since 98'. My Idylle 15.5 runs a 3 blade 22" prop. I get 7.5 knots at 2100 RPM. Great going in reverse. Why ask for anything more. It feathers easily and good service from the company. They'll even though the calculations for you. 8 knots at 2500. BTW I have the variable pitch model. it was worth it to be able to fine tune it with it's adjustable collar.
Nov 28, 2009
495
Max-prop.com From 15" to 30" diameters and from 1" to 2" shafts. Also metric shafts as in mine. When I first mounted the prop, I had the pitch at 13 because I read the matrix wrong. Very low speed. I dove and adjusted it to 18 and has been great ever since.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
I've had Max prop since 98'. My Idylle 15.5 runs a 3 blade 22" prop. I get 7.5 knots at 2100 RPM. Great going in reverse. Why ask for anything more. It feathers easily and good service from the company. quote]
I have had difficulty getting mine to feather. The PO said to get moving over 5 kts, idle down, and bump it in reverse. What do you do?
All U Get
325
Beneteau 393 Chesapeake Bay
Also, as a option, consider some of the better folding props. I have a Gori 3 blade and it works very well. The blades are geared to each other and flip 180 degrees in reverse to present the correct leading edge and blade shape.
May 25, 2004
446
Catalina 400 mkII Harbor
ok, since i have an autoprop. i need to know. why stay clear of them
mike
Nov 28, 2009
495
When the Max prop won't feather and the shaft is still turning after either in neutral or reverse to stop the shaft or after shutting the engine, I would sail into the wind and come almost to a stop. This usually works. I can also reach down to the shaft and stop it by hand when I go into the wind since it is hardly turning at that time.
Not the best, but it works.
Apr 15, 2009
302
C&C 30 Annapolis
Duality,
In areas with a lot of fouling sometimes critters grow in/around the open bearing races on the Autoprops and tend to keep the blades from pivoting properly. Something similar could happen to a Autostream or Maxprop but since they're geared together one or two blades tend to force the stiff one loose.
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
I have had difficulty getting mine to feather. The PO said to get moving over 5 kts said:
We have a 3 blade MaxProp on our H340. We stop the engine while in gear and moving slowly ahead (2-3 kts). Blades rotate into their feathered position immediately because of the flow of the water. I then usually shift the transmission into neutral to minimize chances of starting the engine in gear. I believe this was in the Maxprop instructions.
Once when I forgot to shift into neutral first, then shut down, the shaft kept rotating which I verified by checking below. I stopped the rotation by hand, prop feathered, then I let go - no shaft rotation!
Oct 2, 2008
3,811
That's exactly what I told my wife to do. Uh... do you want the response? "*#^%?! and $&*_+@#$?<":stupid: Then I went down below to try it, didn't work probably because of the speed. Hanging off the swim ladder with your head under the transom to see what's going on doesn't work either. I'm going to try the "Go slow" method.:D
All U Get
Gunni
Mar 16, 2010
5,937
Thanks Ed, that advice on how to assure feathering is really helpful! This has been a big subject with Beneteau owners and our Kanzaki hydraulic transmissions - they need to be in neutral when the engine isn't running. However it can be hit or miss getting the prop to feather if you shut down in neutral.
Real happy with our Maxprop. Good low wind boost to boatspeed. Outstanding reverse power. If I was to buy again it would be the self-pitching Ecowind or at minimum, the externally adjustable pitch model.
