Thinking about using Frog tape
The newest Frog Tape "claims" an innovative treatment that stops "bleed though".Bleed through on the edges
That is the biggest problem. The tape has to be flattened against the hull, and removed the same day as you stated.I use VC17 and have not had a problem with bleed through. Its important to be sure that the tape is tight to the hull. I use a typical bondo spreader to flatten the tape.
You don’t have to wait that long. With VC17 you can launch in 20 minutes.Most of the tapes mentioned will work fine if the edge is burnished hard with a cloth prior to painting. You don’t have to wait long to remove the tape either, just an hour or so.
