While I was searching for what to use on the sole of our h34 and after seeing the cost of teak & holly flooring I was looking for another idea on what to use for the sole. I came across an article on another board about how they created a fake teak and holly sole out of the existing board that was on there boat. So, i decided to play around with a piece of hardwood ply and some whitewood boards. The following is what i did and I think it came out pretty well. I had a piece of original teak & holly floor that was the only good piece left on the boat. I used it for dimensions and spacing for the holly strips.
I cut out the v-berth flooring from a template I made and began routing out the holly lines. Once I completed routing the lines (1/4") I than sanded and stained the ply with a natural teak stain from Zar. After the stain was dried I glued in the strips of holly (whitewood) and applied some marine semi-gloss poly. I than sanded in between coats and reapplied the poly. I used 7 coats in all. The following pictures are from when I started laying the strips in until the final coat and than placed on the v-berth for looks. What you think?
