I recently bought a new engine control panel (tacho, oil pressure, water temp, start, stop and alarms ) on HunterOwners. The panel is a perfect replacement for my 2001 H410, but once wired in, the water temperature shows about 210F (I measured it at 172 F in reality) and the oil pressure shows 10psi higher than before. The shop manual for the 4JH does not indicate any calibrations.
What is wrong? do I need new senders with this nearly identical panel?
Many thanks
JP on S/V Raconteur, wondering in St Kitts.
Many thanks
