im not exactly sure what you mean by "extending the mainsail to get the wrinkles out"....I bought new sails for a Mac 26 c and have a very hard time fully extending the main sail to get the wrinkles out. Some one told me to install a block pulley on the bottom of the mast and one on the deck so I can use the jib winch to raise the main sail. I would also like to put a clutch forward the winch to fasten down the line. Is this a good idea? Ive never attached anything to the deck. Do I just drill a hole in the deck and attach with the proper screw? Would some one please point me in the right direction. The sails are from The Sail Warehouse and are stock for the Mac 26 with nylon slugs with battens. Id like to do this myself but just a bit nervous drilling into the deck. Thanks Robert
the sail is designed to be loose or somewhat baggy in the middle... the luff, leech, and foot can all be drumline tight and the sail will still be loose in the middle with the wrinkles still in it.... it was designed that way.
but over tightening the lines can cause other wrinkles to appear, but they are bigger and usually point in the direction of the line that is too tight. these are stress wrinkles and are not good for the sail or the performance of the boat... you can usually prevent these by NOT getting any of the control lines "drumline tight".....
sustained wind filling the sail on a warm day will take most of the wrinkles out, but unless you remove and roll your sails after every outing, sail wrinkles will be a part of your life...
