up until the last couple of weeks the depth finder has been working perfectly. Now I get readings for 150 to 250 ft deep water when I know I am in 20 ft depth. About half the time the readings are correct. I am not getting any false shallow readings, only false deep readings. Should I try to clean the thru hull transducer first, or check for corrosion on the wiring connections?Scott
