in MN. You may have to take a few measurements 1st. They will tell you where to take the measurements. They can then give you a range of thickness & degrees of lift on the templates. It is a big job to tackle, & you probably will need to epoxy seal the entire bottom of the boat along with the keel before you put on the VC17. My suggestion on the templates is to go for the wider stearing grove. Talk to West System re the epoxy application. It has made a big difference on my H34.BOLPJ
