G
Gerald Sundberg
My 1990 Catalina 30 is equipped with the Universal M-XP25 diesel. The Sherwood Raw Water pump has given up the ghost. Does any one know of a replacement source? Is there a better pump I can change to? The pump sucks in a lot of weeds and I have replaced the impeller numberous times. The job is difficult since the bolt heads are between the engine block and pump body and with the hose and alternator belt configuration it's a difficult repair to make. I would appreciate any information you could give me. Thank you.
