I did
Hello,I used EZ off in the spring of 2005 to remove the pained on letters on my boat. The EZ off worked very well. There were still some faints marks from the paint, but not too bad.If you do use EZ off, be sure to wear long rubber gloves and eye protection. Spray it on, let it sit for 5 minutes, then scrape and rub it off. I found that a plastic scraped worked best. That, and lots of rags did the trick. Before EZ off I tried polishing compound, automotive compound, and acetone. Nothing worked.Good luck,BarryBarry LenobleNoble PrizeMt. Sinai, NYlenoble@optonline.net
