I bit the bullet and removed those thin strips of teak that run along the top exterior edge of the coach roof. They are so thin and long that maintaining them is a nightmare and on one side the wood had broken in half in two places. I countersunk the screw holes and filled them with a thickened epoxy mixture. I plan to get some blue vinyl tape and run that along both sides to cover the filled screw holes so I don't have to worry about gel coating the holes and matching colors and to give it the same look. Anybody else ever tackle this on a 34 or 35?
I sanded and coated all the rest of the exterior wood over the last week, what a PITA. Using Cetol they want you to put on 4 or 5 coats with 24 hours between each coat. I'd like to replace all the caps on the toerail with stainless steel also. It is a real body breaker to refinish those little strips considering there is about 50 feet of them all in difficult to reach positions.
