extra halyard
P
Paul Case
I bought my 31 with the mast already up. Can anyone tell me if there are empty sheeves at the mast head to run an extra jib halyard?
F
Frederick Pierce
Empty Sheeves
HI, PAUL It depends what mast you have I think they used the isomat mast and it would have three sheeves I have on my 28 oday the isomat mast and my records it shows the 28, and 30 is the same but I would ask RUDY he would know . good luck Frederick Pierce
james rohr
get your boson's chair or binocs
my 30 has a kenyon spar. had 4 sheaves, 2 forward 2 aft. but halyards used all as they were run outside mast.with halyard winches mounted on mast. I moved halyards to inside and winches to cabin hesd.now i have 2 jib halyards,main and adj. boom lift. if your winches are mounted on mast and halyards run out side, more than likely there are 4 sheaves.
