Exterior Control Panel
1
Hunter 27 Cave Run Marina
I'm trying to locate an exterior control panel for a Hunter 27. Any suggestions where I might find one?
May 24, 2004
7,237
CC 30 South Florida
Do you mean the control panel at the cockpit? If you have a Yanmar engine it is a Yanmar part. The control panel or the housing for the gauges comes in two types one which includes the opening for a tachometer and the other one that does not. These housings are very reasonable in price and can be ordered trough any authorized Yanmar dealer. For the 1GM Yanmar the part number is 128170-91010 $28.58 and if desired the gasket for it is $7.44. I believe this is for the B panel which has the tachometer but be sure to clarify the correct part and part number with the dealer.
