A
Andre Michel
the galvanized exhaust pipe on my 1972 Catalina 27 with an atomic 4 was corroded so badly that it split in two while i was motorsailing one evening i was taking on water until i figured out what happened and plugged the pipe meanwhile i proceded to consrtuct a new exhaust system to the exact size as the old one the engine seems to have suffered no damage no water entered the engine however the loop in the pipe is about 3 inches short of the engine compartment top should it rise as far as possible to eliminate the possibility of water making its way back through the system and entering the engine when not on ? should there be a rubber flap on the exhaust through hull to prevent back flow ? thank you
