Excess paint rewmoval
7,743
Alden 50 Sarasota, Florida
soda blast around $50/ft
DIY sand if you have the free time and appropriate equipment but make sure you don't penetrate the gelcoat.
It all depends on what it is you are trying to achieve - racing bottom or good enough for cruising, what type of paint is currently there, what paint you want to put on, etc... The more info you can provide, the more responsive we can be.
Tim R.
May 27, 2004
3,626
Best DIY job, in my opinion, is walnut shell blasting. Very easy to master and needs no specialized equipment unlike soda blasting. I would not recommend sand blasting. Walnut shell blasting equipment is not much different from sand blasting equipment you can get at your local tool rental.
Go to ericsonyachts.org and search on "Walnut"
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
If ablative clean the bottom every month. Within a couple of years you may have gotten rid of all the excess at no extra cost.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Benny—
It's pretty unlikely that the paint is ablative, since there is an excess build up of it. :)
