Mike Elmore
Hello. I am leaking water/exaust from the box end of the hose that connects the header pipe to "the box it goes into." Engine model is Univeral M3-20. First, what is the exact name of "the box"?Second, has anyone else had this happen? If so, what am i going to find? Tightening the hose clamps a bit didn't fix it. I tried to get the hose off, but its really stiff so I'm probably going to take the header pipe off to see if I can get it loose. Is some high temp sealer around the base after I see what is going on a good or bad idea?Thanks,Mike ElmoreWindward HullC28 - Hull #7
