wing specs
Hi Mowindsurfer, I have an '89 wing keel and the draft is 2'6", it shoud be the same for your boat. Catalina made a change in 1995 with the Mark II. I'm not sure of the changes that were made from '95 on though. With your boat being a '94 these specs below should OK for you to reference; Draft 2'6", ballast 650 lbs., Sail area; I=(foretriangle height) 25.83', J= (foretriangle base lenght) 8.00', P= (mainsail luff) 21.00', E= (mainsail foot) 9.66', sail area 212 sQ. feet, Overall lenght(LOA)=21'6", waterline lenght (LWL)=19'4", beam= 7'8", Mast lenght= 25'0", Displacement= 2490lbs min., and pop top down head room would be 4'4", and with the pop top up 5'7". Hope this helps you, and, if catalina didn't do anything strange with your '94 (like change things on your boat because it was approching a new model, the mark II, and made your boat, say a '941/2, you should be able to use the above. Take care, Jay
