Evolution of the H34 Design
Ketoj
Jun 5, 2004
55
Hunter 34 Whitby Ontario Canada
In various topics and threads there has been a good deal of discussion on the evolution of the Hunter 34 design as it progressed through the years. I'm starting this thread in hopes that owners will provide enough info that we can establish the progression (or regression) of its various design features. Should this thread get traction I'll consolidate the results in a document titled "Evolution of the H34 design."
I'll start with the basics of my boat:
Hull#: 44 (HUN34044M83D) Note: The 9th character "M" indicates Hunter is using the model year format. This means the last letter denotes the month of manufacture (the system starts with August = A, Sept = B, Oct = C, etc.)
Mast step: Large plate
Compression Post failure: No
Engine: Westerbeke 21
Anchor Locker: with large cleat
Interior: Teak
Stearing: Merriman
Furling: Stream Stay
Other: no storage cut-out to right of galley sink, stainless compression post to left of galley sink (retrofit or factory?)
Please add any other feature you know changed over the years.
Thanks everyone!
281
Hunter 34 Havre de Grace
#95 HUN34095M83F
Differences:
Engine : Yanmar 3GM(F)
Furler : Hood
No stainless post near the galley.
Mar 8, 2008
53
Hunter 34 Vermilion
Really good idea sharing the differences !
Hunter 34: Hull #233 #
HUN34233M83I
Engine: Yanmar 3GMF
Mast Step: Small plate
Compression Post Failure: Now checking, very suspicious that inspection of post paid for in 2009 did not happen :-(
Rudder: Large rudder
Anchor Locker: With Cleat.
Main cabin table: No condiment compartment.
Rear water tank: Filler in aft lazerette [I have never put water in the rear water tank]
Interior: Teak
Jib furling: Hood
Steering: Merriman
Compression Post Left Of Galley: Not on mine.
Storage space right side of sink: Yes
Hand holds on deck: 1 short & 1 long on either side [total 4]
Batteries: 2 in starboard lazerette.
Fixed port frames: Aluminum
Roy
890
Hunter 34 Toronto, Ontario Canada
Interesting idea, Jerry.
Hunter 34 HIN HUN34327M83K
Engine: Yanmar 3GMF
Mast step: Small plate
Compression post failure: None
Rudder: Large ( had suffered damage from freezing0 fixed 2003)
Anchor Locker Cleat: Yes
Main Cabin Table: No condiment Compartment ( always wondered what that would be called!) Table finished in formica or like substance
Rear water tank filler: under teak step at stern
Interior Teak
Jib furling: CDI ( probably original judging from the appearance
Steering- Merriman
Compression post left of galley- no
Storage cutout right of sink- yes
Prop- 2 blade 12P 15 dia
Aluminium fixed port frames
2 long teak hand hold rails on deck.
Mar 25, 2010
152
Hunter 34 Rose Haven MD
[FONT=&quot]
Ok here we go ….
1984 Hunter 34: Hull #525 #HUN34525M84F
Engine: Yanmar 3GMF
Compression Post Failure: Not yet
Rudder: in water so not sure but 84 hull 525 should be the new rudder
Comment from other posts - Only the early 1983 boats had the wrong rudders - At some point, definitely after hull #170, they went to the bigger rudder on the 34
Main cabin table: WITH condiment compartment.
Rear water tank: Filler aft of lazerettes hatches next to rudder post top under wood plank.
Interior: Teak
Jib furling: Not original but have Harken
Steering: Merriman
storage cut-out to right of galley sink: Yep got one
Battery location: Starboard lazerette
Fixed Ports: Plastic frames
Also here is some info from another post by Don Johnson
My hull number is 113, shoal draft with a Yanmar 3GM30F, the big mast step, metal window frames, no counter top cut out to starboard of the galley sink, and the large cleat in the anchor locker.
Scott[/FONT]
Hunter 34 Alameda CA
We bought Alchemie brand new in April of 1985. It was delivered with the following:
1985 Hunter 34: Hull #798 #HUN34798K485
Engine: Yanmar 3GMF22 (the one with the cylinder sleeves)
Prop: 15x15 two blade.
Keel: Cast Iron
Compression Post Failure: You bet! First one to live and tell about it.
Rudder: Big rudder
Spar: Kenyon (white powder coated as opposed to the Isomat anodized one in the brochure pictures)
Anchor Locker: No Cleat.
Anchor: 22 lb Bruce
Main cabin table: WITH condiment compartment only we took it off as I bash my knees on it and my wife uses it as a foot rest under the table.
Rear water tank: Filler aft of lazerette hatches next to rudder post top under wood plank.
Instruments: Signet Knot Meter and Depth Sounder
Interior: Teak
Jib furling: The dealer "gave" us a Cruising Designs Reefer II. It was all plastic, but we have taken care of it and it works fine. I like it as you can raise the sail to a lock and retreve the halyard. There is a downhaul setup to tension the luff.
Steering: Merriman (Cracked Housing)
Compression Post Left Of Galley: No.
Storage cut-out to right of galley sink: Yes
Battery location: Two group 24s in the starboard lazerette
Winches: Two self tailing Maxwell 24 jib sheet, 2 Maxwell 20s on cabin top.
Stove/Oven: Origo 6000
Oct 14, 2005
2,191
Continuing the track...
Intrepid's data (all thought to be standard as produced and commissioned):
Hunter 34 HIN: HUN34113M83G
Engine: Yanmar 3GMF
Mast step: Large black casting
Mast (and boom): Kenyon #BF002311
Single reefing in boom rigged
Rudder: Small shape (H31 origin)
Steel shoal keel - 4' 3" draft
Main Cabin Table: No condiment Compartment; Table finished in white formica-like substance with no fiddles
Interior: Teak
Jib furling: Hyde Stream Stay
Steering: Merriman w/42" wheel
Raymarine ST-4000 autopilot (Mfg date of 1984)
Ritchie Helmsman Compass in pedestal
Lewmar self-tailing winches: Main and cabin top
Four cabin-top line stoppers (set of two per side)
Compression post left of galley: stainless post was not standard
Storage cutout right of sink- no
Origo 6000 stove/oven
Prop: 2 blade 12P 15 dia right hand
Four storage drawers at center of v-berth (others seen to have 2)
No sink in aft compartment shelf (noted on very early model)
Ketoj
Jun 5, 2004
55
Thanks everyone, keep the replies coming! Some very interesting feature changes over the years, including some I've not heard of before. I'm consolidating and building the history now.
I listed interior as teak because I'd swear I had heard some later years used other woods?
Nov 6, 2006
10,256
Evolution of H 34
Data on my '85.. I copied Allan's and changed as appropriate.
1985 Hunter 34: Hull #798 #HUN34815A585
Engine: Yanmar 3GMF (the one with the cylinder sleeves)
Keel: Cast Iron
Compression Post Failure: Not compression post but the beam it bears on failed; Fixed 3/2010
Rudder: Big rudder
Spar: Kenyon BF 8386 (white powder coated as opposed to the Isomat anodized one in the brochure pictures)
Anchor: 22 lb Bruce (po added next size larger Bruce also)
Main cabin table: WITH condiment compartment, no fiddles
Instruments: Signet Knot Meter and Depth Sounder and Wind indicator
Interior: Teak
Jib furling: Harken "UNIT 1"
Steering: Merriman (Housing cracked and replaced with cast aluminum one)
Battery location: Two group 27s in the starboard cockpit locker
Winches: Two self tailing Maxwell 25 jib sheet, 2 Maxwell 22s on cabin top.
Two Lewmar self Tailing 43's added by PO with spin gear
Stove/Oven: Origo 6000 replaced by Seaward 3172 propane (3 burner + oven)
Marc
6
Hunter 34 Lake Champlain
1986 Hunter 34: HIN 35015C686
(Note: 35 designation )
Engine: Yanmar 3GM30F
Prop: bronze folding 16"RH.
Keel: Cast Iron
Rudder: Big rudder
Anchor: 22 lb Bruce
Instruments: Comnav Knot Meter and Depth Sounder
Interior: Teak
Jib furling: Harken
Steering: Merriman w/ Yacht specialties 40" wheel
Winches: 2- Lewmar #43
2- Enkes #AR18
1- Barient #21
1- Maxwell #21
Stove/Oven: Origo (2 burner + oven)
Sep 21, 2009
385
Hunter 34 Comox
Heart of Gold is pretty standard. Hull # HUN 34767I485
Compression Post failure: First signs, replaced last year
Engine: Yanmar 3GMF
Anchor Locker: with U bolt cleat
Interior: Teak
Stearing: Merriman
Furling: Harken
Other: storage cut-out to right of galley sink, No stainless grab post to left of galley sink (retrofit or factory?)
Condiment storage in table
Origo Passive alcohol stove and oven
Norcold refrigeration(may have been retro fitted)
Hot Water: electric and engine heat
2 blade prop
Schaefer traveler, Genoa cars,
Maxwell 23 self tailing primaries and smaller standard cabin top halyard winches
Sep 21, 2009
385
Hunter 34 Comox
I should add that I have upgraded many components and changed/added a few things but I only included the stuff about the boat as I found her.
Jan 21, 2011
7
Hunter 34 Grapevine, TX
My Hunter 34 (Le Chasseur) was purchased new in December of 1986 by a deceased friend of mine. I purchased Le Chasseur last year (2010) from my friend’s widow. My friend saw the Hunter 34 at a boat show in 1986 and ordered Le Chasseur. He took delivery in December of 1986. I believe it must have been one of the final boats, as I believe they were also making the Hunter 35 in this time frame.
It appears that Hunter started re-numbering the Hunter 34 in the 1986 Model year and they also started the HUN35 designation in the HIN. I always thought my friends boat was a Hunter 34 but the HUN35 on the transom lead me to believe it may be a Hunter 35. After a lot of Internet searching I determined it was a Hunter 34. It is also documented as a Hunter 34.
As per a previous posting “Kloudie1” is Hunter 34 Hull number 815 and was manufactured in Jan of 1985 so Hunter was almost up to the three-digit limitation in the HIN.
Le Chasseur's data (all thought to be standard as produced and commissioned):
Hunter 34 HIN: HUN35073J687 - which means it is hull number 73 manufactured in October of 1986 and is a 1987 Model.
Engine: Yanmar 3GM
Mast step: small plate
Mast (and boom): anodized aluminum
Single reefing - in boom rigged
Rudder: should be later model style
Iron keel - 5' 6" draft – I have read that they added a little more Iron to the latter models.
Anchor Locker Cleat: U-bolt tie down
Anchor: 22 lb Bruce
Main Cabin Table: Condiment Compartment in table; Table finished in light blue Formica-like substance
Rear water tank filler: under wood step at stern
Interior: light Oak – I think this may be the same wood as the early Hunter 35s.
Jib furling: CDI
Steering: 40” wheel
Auto helm autopilot – Added by original owner
Compass, Knot meter and Depth sounder in pedestal
Battery location: Two group 27s in the starboard Cockpit storage area
2 self-tailing winches in cockpit (I think Maxwell) and 2 non self-tailing on cabin top
No Compression post left of galley:
Alcohol stove/oven
Prop: Replaced 2 blade 15” dia right hand with 16” Martec folding
Two storage drawers at center of v-berth
Refrigeration added to Ice Box and Air-conditioning forward of sink added by previous owner.
418
Island Packet Island Packet 29 West River, MD
I bought my 1983 H34 in June, 2001. At that time this is what it had:
Hull # HUN34170M83H
Draft 4'3"
Mast step is the large black plate
No compression post problems to date
Anchor locker has the large cleat
Anchor is a Bruce 22
Two large handholds on deck
Yanmar 3GMF
Two blade prop
Pedistal is a Merriman
40" wheel
Spars are Kenyon
Furler was a CDI
Small H31 rudder
Fixed port frames are aluminum
Aft tank filler is in the bottom of the port lazarette
Two Lewmar ST 40's for jib sheets
Two Lewmar ST 16's on cabin top
Double clutches were on each side of cabin top
Interior is teak
No galley post
Cutouts to the right of the galley sink and aft of the stove/oven
Table has no condiment storage & is rectangular with a white formica top.
Four storage drawers under v-birth
Plastic sink in vanity
Feb 8, 2010
78
Hunter 34 Grand Lake
Indigo's data (all thought to be standard as produced and commissioned):
1983 Hunter 34 HIN: HUN34083M83F
Engine: Yanmar 3GMF #01860
Rudder: Large 16" bottom
Iron Keel Deep Draft 5'6"
22 lb Bruce and 13S Danforth in the anchor locker
Rear water tank filler: inside Lazerette port side
Interior: Teak
Jib furling: ProFurl (not original)
Steering: Merriman
Signet Knot meter and Depth sounder in pedestal pods
Lewmar self-tailing winches: ST 40 Main and ST 16 cabin top
No post left of galley: stainless post was not standard
2 Deck Solar Vents aft of forward hatch (standard equip)
Plastic Sink in Vanity
