Evaporative A/C
3,811
Pearson/ 530 Strafford, NH
What we have discussed so far only needs to be simply modified such that WHEN ANCHORED for the evening, all one might want to do is to toss a hose overboard and pump cold water up from the bottom to run through the heat exchanger.
I'd even go so far as adding a quick garden hose connect to a through-hull in the transon. When in use it would reduce some of the head and then capped when sailing. When are we going on "Shark Tank"?
All U Get
DanM
Mar 28, 2011
155
Catalina 30 Galveston Bay
shipwreck66,
Your maths seems logical to me, but after installing a battery monitor this year I did find a few things in my boat that didn't quite run the way I calculated them, so it's hard to say exactly what is going on without one.
A group 31 battery is somewhere in the neighborhood of 110a/h though, so in theory you wouldn't run to pull more than about 55a/h out of it on a regular basis or will dramatically shorten it's life. Of course there is some give and take depending on battery type, but this thread is about the evaporative A/C so I don't want to hi-jack it.
The ideas are very interesting though, I'm looking forward to the results!
DanM.
Apr 5, 2010
565
Catalina 27- 1984 Grapevine
Don't worry Dan, it's all about power here. If I had a fancy inverter I could run the window unit on a series of Group 31's, already tried using a regular one, unit kicked on, kicked off, kicked on etc. This is a weekend toy so if I ruin the battery, no real harm done, it is not connected to the two house batteries, those I leave alone. Cruisair has a neat little boat a/c unit designed to run off a series of 12v and comes with a continuous sine wave inverter, for around $2900, and only puts out 3500btu of cooling, and still requires the two thru hull water lines. In this Texas weather 5000btu is minimum.
