EV-100 auto helm issues
Catalina 34 Casco Bay
My autohelm has been acting up and I just wondering if anyone else has experienced this and may possibly have a solution.
When engaged and it is making corrections the lock lever starts to move up towards free and then back down. Then on the up movement, to releases and the course is lost. This happens in both sail and motoring.
Anyone ??
Thanks,
Rick
RoyS
Jun 3, 2012
1,742
Probably the clutch needs adjustment would be my guess. You might want to have a new belt handy in case it was damaged. Did anyone try to force the wheel when it was in auto mode?
Likes: sailme88
Jan 7, 2011
5,877
Oday 322 East Chicago, IN
My old ST4000 does that when it dirty inside the wheel…I usually open it up, clean things up, adjust the clutch if necessary and put it back together. Usually need to do it once a season when the clutch starts to “disengage on its own”.
Likes: sailme88
:plus: With Greg regarding cleaning the insides of the EV100 wheel control. Dirt and salt build up inside and a cleaning plus carefully lubing (light weight jewelers oil) certain parts helps. NOT THE BELT!
An important discover I recently made was the need to clean out the inside of the wheel unit and to lightly lube the roller under the belt of the "eccentric" gear. Doing this really improved the operation of my Wheel AP. It stopped jumping.
Another improvement on my unit was to acquire a replacement clutch lever from a fellow in Canada. He 3D prints the units in a stronger plastic than I received from Raymarine. It also correctly sits over the locking nub on the wheel unit frame, which my Raymarine part did not do.20BAF04B-7901-4EEC-BBBF-4481E289CFE2.jpegD18374D0-5D8D-49A4-857C-DD444A9967AF.jpeg
Locking nubs
3D printed clutch arm with enlarged space for locking nub.
Likes: sailme88
Nov 26, 2014
51
HUNTER h31 Northport L.I.
I've had that same problem, it required me just to tighten set screw that holds lever on as it eventually comes loose with all the engage and disengage movement good luck Eddie
Likes: sailme88
RoyS
Jun 3, 2012
1,742
When disassembling the wheel drive assembly be gentle. It is easy to break the plastic parts inside. As far as cleaning the inside, you could probably just flush with a hose without disassembling. A new wheel drive unit costs $550. Ask me how I know.
Not to my knowledge...
Sailme88
Raymarine, and before them Autohelm, designed in the possibility to turn the wheel by force should the wheel system stop working. Essentially turning the wheel against the motor in an emergency.
As you can imagine with the belt, an eccentric clutch gear, a geared electric motor and bearing wheels of extruded plastic held together with screws things can bind and get sideways while the boat is operating.
akar7
Jun 29, 2004
3
I had the same issue. Adjusting the clutch and then replacing the clutch cam assembly didn't correct the problem.
I was able to repair the issue by shaving about 1/32" off the clutch arm shaft which added slightly more friction to the clutch lever.
You could also add a thin nylon washer to the backside of the clutch arm which would add the same additional friction.
Likes: sailme88
@markwbird here is the guy.
Out of Ganges, Canada. Tell him you heard it from me. I told him that if he got it right that I was sure others would ask about his design.
Mar 20, 2011
623
Hunter 31_83-87 New Orleans
Had a similar issue when the plastic locking nub broke. Raymarine will sell the rear ring for about $120. Something they don’t advertise. Better than full the wheel drive assembly. If you go this route look at you tube videos on capturing and installing the little bearings If they get away from you. Ask me how I know too.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
1
Catalina 36 Redondo Beach
Wash with water. No need to disassemble. And then put a bungy cord on the arm to provide tension so that it doesn't open. No need to replace. Has now worked perfectly for two years.
Oct 7, 2023
6
Cape Dory 330 South Portland, ME
EV-100 Autopilot was installed last year, works great, but when not on or in standby there is a decent amount of clutch drag. I have read the manual and it tells me to loosen the screw and turn the clutch knob to the left, but after greatly loosening the screw I cannot turn the clutch knob as instructed. Any suggestions?
Drag may be caused by dirt in the wheel a good rinse with a little dish soap may flush the wheel and freeing the gears.
Failing success you may have to open the wheel unit up. If this gives you the he-be-gibes then seek support from a Raymarine service center.
Oct 7, 2023
6
Thanks for responding. Tried to run water through the back in my sink but didn't seem to help. I did install it, so I think I could take it apart.
Remove the wheel and open the ring that contains the friction tape. Soften the screw's retainment, check it and replace the wheel.. Try it again back in place before buttoning it up.
Oct 7, 2023
6
I brought the wheel home, this morning I removed the cover (opened the ring) and could see that the clutch knob was open as far as it could go. Though everything looks very clean (only a year old), I rinsed it out with soap and water and put it back together. When I turn the autopilot, it still is dragging. When you say, soften the screw's retainment, I am not exactly sure what you mean. Is that a screw inside the ring? Appreciate your thoughts.
There is a square-ish type knob on the forward side of the control wheel that maintains the tension on the friction tape. That knob should have a screw in it. Ease it off ( soften it's grab) and see if that allows you to ease the drag.
Oct 7, 2023
6
After I loosened the screw in the knob, I turned the squarish knob counterclockwise all the way to where there is a stopper (I can see this with the ring off) and the wheel still drags. I am wondering if there is any other adjustments I could consider with the ring off. Just seems like the belt is grabbing more than it should. I may have to take the wheel into a Raymarine dealer to see if they have any other suggestions. I do appreciate your thoughts
