Eu3000si
2
Hunter 37.5 ND
Does anyone know if a Honda eu3000is will run the A/C on a 1993 Hunter 37.5? Thanks
5,802
It will if the unit is 16K btu or less. I can run my 12K Mermaid A/C with my 2000W Honda.
Nov 26, 2006
381
Hunter 31 1987 Fly Creek Marina Fairhope,AL.
It should run it fine if you do the math.
The gen set is 3000Watts.
To determine what the A/C requires, Simply use this formula.
AMPS x Voltage" usually 120Volts" = WATTS
So we have 2 of the 3 variables as follows.
3000/120=25 AMPS " current"
7,733
Alden 50 Sarasota, Florida
The critical element is the start or in-rush current requirement of the A/C unit. Without know which A/C you have, you really don't know for sure unless you find out, tell us or try it on a rental.
Mar 12, 2008
557
Jeanneau 49 DS San Pedro, CA
Just keep in mind that the normal operating range of a generator is 75% of the rated maximum capacity. That drops the 25 amps down to about 19 amps.
