Espar Heaters
Merrill Mant
I have searched the archives and have not found many comments concerning the Espar hot air heating systems. We are northern NY sailors and the spring sailing is in very cold water and in the fall, the air is chilly. I have not been impressed with the kerosene heaters (Dickerson / Force 10)... odour more than anything. I would appreciate any comments positive or negative about the Espar forced air heaters.
Rick D
Jun 14, 2008
7,201
One Possibility, Merrill
I think John Farnsworth in San Francisco installed one on his 410. Check the owner's directory and shoot him an e-mail. Rick D.
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
Had one, loved it
Installed in a passage 42. Heated the boat quickly, kept it very dry. Only draswbacks; takes a fair amount of space in a locker and because it gets hot, you may not be able to use the locker for anything else. It was fairly loud outside the boat; sounds sort of like a jet engine. The key is installation. Make sure you hire someone who has worked with these heaters before, on boats.
Jul 1, 1998
3,062
Espar Air and Water
Espar makes both forced air and hot water heaters (for use as a space heater). The smallest hot water heater is capable of 13,000 BTU per their advertising. One of the advantages of the water heater is the holes one needs are much smaller than for forced air. Something to consider especially if one wants to run heat to the far ends of the boat. The ducts for the forced air heaters are fairly soft aluminum and damage easily so they need to be located in places where they won't be easily damaged or squashed. If running them through a space where there is a lack of protection an option is to run the duct inside a plastic pipe. Ask the dealer about fuel pump noise. Some heaters have pumps which make a clicking noise than can be annoying and some heaters are better than others in this regard. Diesel heaters, which use a glow plug, like good current and high voltage or the glow plug will warp, smoke, and be a maintenance headache. Since they require a motor it's a good idea to upsize the wire for current over continuous operation. Motors require about 3.5 times more current to start up than to run. Standardly the fan runs first and then the glow plug kicks in so it would be good to check for current needs at this point too.
C
carl
Espar Heater
Merrill, I have an Espar hot air heater in a 34'cal. I'm just accross the lake from you. If you want, give me a call at work (chanel 3 (tv)check your phone book} and if you want, I can show you how it works, in person. Carl
K
Ken Sturgill
Had One
It was great, I wish I had it oon my new boat, it has a Force Ten propane, really not as nice as the Espar.
