When to repair Individual Blisters
Gelcoat blisters can be a serious problem if left unattended. At some point, your hull may need extensive repair, including gelcoat removal and epoxy barrier coats as described in “Gelcoat Blisters: Diagnosis, Repair & Prevention” (West Systems #002-650). However, if you have isolated blisters and a manageable number to repair individually, it’s often recommended that you patch individual blisters and continue to use the boat until you determine the cause and extent of the problem.When does filling individual blisters make sense?1. There are not many blisters on the hull. It is far easier and more sensible to fill a few blisters than to start peeling the gelcoat. Fill them and inspect each time you haul the boat.2. The boat has not had blisters previously. It makes sense to repair the newly developed ones, then wait and see if more develop. These may be the only blisters that will ever form, or a small number may form each year that will require repair on an annual basis.3. You just bought a used boat and have found a few blisters. Fill the individual blisters and investigate before doing a complete barrier coat.4. You can improve ventilation and see if this solves the problem, making a complete barrier coat unnecessary. There appears to be an inverse relation between ventilation and blisters. More ventilation-fewer blisters. Fix individual blisters and then improve ventilation.5. Funds are not available for a complete barrier coat.6. The boat may not be worth the expense of doing a complete barrier coat repair. It costs a lot of money to have the job done by a yard, currently about $200 a foot. This may add up to more than the resale value of the boat. Additionally, costs of storing your boat out of the water just to dry and prepare the hull can add considerable expense.7. You want to get your boat into the water so you can go boating. The time required to properly prepare and dry a hull may be longer than you want to wait. To do a full barrier coat, the boat will have to dry for a period of time. This can be accelerated with heat and dehumidifiers, but if you are depending on Mother Nature, drying time can be months.
