Marine epoxy barrier coats have been in use for 30 years as a proven treatment for hull blistering and we have known for years what causes blistering - the permeability of gelcoat /polyester, hydrolyzation of polyester resins used in hull laminates; and the hydroscopic nature of glycols in polyester resins drawing moisture into the laminate. And no, the manufacturer (who happens to be my manufacturer - Beneteau) does not void a warranty for sanding their gelcoat to put on a barrier coat. And no, all epoxy resins are not the same.
So to the original poster, choose an epoxy formulated for marine application, not by the resin/hardener mix ratio. I like WEST, MAS, and RAKA, ask a marine tradesman what they recommend. Make sure you get the specified epoxy film thickness. It is a pretty fool-proof DIY product, with lots of uses.
