Epoxy pumps
3,815
Pearson/ 530 Strafford, NH
Hi all,
I was using the old west systems epoxy on a house project and finished the cans. Is there a way to clean the epoxy hand pumps or just let them drip clean? I may not get to use them for a while.
All U Get
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
I have let the pumps slowly drain, then put them into a Zip-Lock bag for future use WITH THE SAME EPOXY COMPONENT. I put the resin pump in one bag and the hardener pump in another. I'm not sure what you could to effectively flush them out. If any thing could be used for flushing, it would probably be two separate flushing agents.
Oct 2, 2008
3,815
I've used rubbibg alcohol to clean my fingers after working with it and it seems to clean up ok. West systems says to:
Clean resin or mixed epoxy residue with lacquer thinner, acetone or alcohol.
I'm thinking that would be good enough. :confused:
All U Get
Mar 26, 2011
4,045
Corsair F-24 MK I Deale, MD
You don't need to do anything. Just cover the tops to keep the dust off. I have had them last 5-10 years with no other attention.
JVB
Jan 26, 2006
270
Schock Wavelength 24 Lake Murray, SC
Lacquer thinner
Lacquer thinner has worked for me on other epoxies.
