Epoxy Paint
Sep 4, 2007
795
Hunter 33.5 Elbow, Saskatchwen, Can.
Good morning
Has anyone ever used epoxy paint on the cast iron keel? Like pool paint?
If the keel is prepped correctly, do you think it would adhere?
Epoxy paint works well on properly prepared steel or iron keels. We've been using it on a steel schooner.
The iron needs to be throughly cleaned and brought to bright metal by sanding, grinding, or sand blasting. Immediately coat the keel with a Phospho or similar product to convert the iron oxide (rust) to iron phosphate. Iron phosphate is a paintable surface. Then paint the keel with an appropriate epoxy paint.
Epoxy paint can have different formulations to meet different requirements, I'm not certain if epoxy pool paint is a good match for for a sailboat keel. While a pool bottom and a keel are both submerged, the substrates are different. The characteristics that make a good paint for a concrete surface may be not work as well on an iron keel moving along at 6-7 knots. There would also be temperature cycling, a pool, especially an indoor heated pool will not have the same expansion and contraction cycles that an iron keel will experience. My choice would be a marine epoxy barrier coat. Both Pettit and Interlux make epoxy barrier paints and should be available in Canada.
Nov 6, 2006
10,244
I have used Interprotect 2000 and found that it doesn't adhere all that well .. The next time I do my cast iron keel, I will use a coal tar epoxy. that stuff is very durable and is extremely tenacious.. It is used on underwater structures and barges to keep corrosion in check.
I’ve had success with interlux on my cast iron keel. There are several places the original coating wore through that I’ve sanded and coated with Interlux over the years. I don’t think any of the original spots have reappeared.
Likes: BigEasy
Jun 21, 2004
3,212
Beneteau 343 Slidell, LA
I have used interluxe 2000E on my cast iron keel to repair rust spots. Seems to work well. Many years ago when I owned a Hunter 33.5, we sand blasted the keel & applied a primer, followed by cal tar epoxy; it held up well also.
After doing the prep, which is the majority of the work, why use an uncertain coating technology? If the OP doesn't have access to the known products I guess I can see looking for an alternative.
I would ask the painting company about the available paint.
  • What is PREPPED CORRECTLY for the surface you are intending to cover?
  • Can this be done to the surface of the material you intend to cover?
  • How long can I expect this paint to last on my project when submerged in the water and under the conditions of use?
Their answers to these questions should provide the guidance you need.
Sep 4, 2007
795
No painting company here. It's all DIY and any club members that you can convince to help. But everyone is in the same boat getting boats in the water.
