F
fred
Know your hardner
If you use the West Epoxy system and plan to overcoat with a uv coating like polyurethane be sure that you check out that you are using the correct hardner because if you don't have the right hardner the polyurthane will not dry.I know I had to redo my project and strip everything. It took an additional 30 hours of work when it only should have been total job of maybe four hours.. West Marine made the reccomendations as to hardner and at least replaced material
