I am in the process of adding a teak beam (for a traveler) that will mount at the far ends (port and starboard) of my coamings. I've already modified the tiller so that it now pivots (vertically) inward of this traveler beam. The beam is mounted to two riser teak blocks (one on each end) and each of those blocks will mount to the coaming using two SS plates (one on each side of the coaming). So there are four stainless steel mounting plates all together.
I will be drilling the coamings to through-bolt the four plates. Each bolt would go through a plate, one wall of the coaming, another wall of the coaming and then the other plate before being fastened with a nut.
The port side of my cockpit does not have a lazarette. So I have cut an access port hole that allows me to reach the hollow area inside the port coaming. Actually, it turns out that these coamings are supported near their tops by what must be wooden beams which were fully glassed-in by O’Day. So those beams sit right beneath the top fiberglass skin of each coaming. Below that, however, the coamings are hollow. I want to fill the hollow far ends of each coaming (near the stern) where the plates will be bolted through.
I'd like to find a material that I can work into those hollow spaces (in each coaming) so that they end up solid fiberglass/epoxy/plastic etc. all the way through (from the stern end of each coaming in for about a foot or so towards the cabin). The challenge, and it is a big one, is that I need to stuff this material in primarily from below the cavity. So I'd need something that, in working form, is almost like clay but which dries to a solid and waterproof sort of plastic. I almost need a sort of slow kicking epoxy play-dough that can be molded into the space and then harden and bond.
On the starboard side I will be adding the material from below after crawling into the lazarette. So the challenge is the same.
Any ideas for what a good marine equivalent would be? I need something that would stay moldable for several minutes while I worked it in to fill the cavity.
