Engine
C
courtesy730
I have a M-30 I just bought. Universal is frozen. Can anyone tell me a good replacement engine for this boat. It seems as thought I may be limited since size and location of engine bay are limited(under balley sink/sette area. Would a Yanmar 2gm series fit? Ideas?
Thanks,
Curtis Carter
Swift III
Replacement engines
You're correct about size on your boat (assume you meant C30, not M-30).
A friend recently replaced his old M25XP with an M25XPA, essentially the same size, in his C34. Although we have a lot more room in our engine compartments, the motor is pretty much the same size and the hoses connect in the same place. If you change engine manufacturers, you have a lot more work ahead of you for connections of different parts, like exhaust risers, wiring, alternators and electrical wiring. The Yanmars also don't have glow plugs like the Universals do.
Mar 15, 2009
61
2 30 Stingray Point Marina Deltaville Va.
I had a Universal 5411 when I bought my boat. It seized, I replaced it with another 5411. The actual install took all of three - four hours total with a hoist.
Mar 15, 2009
61
Also, I know where there is 5411. My old one which is being re manufactured up in WI. I would be happy to give you the guys information. I paid 2700.00 for mine with a new transmission to boot. ALL new internals on both and a year warranty.
May 23, 2004
3,319
Hrm. I think that I would stick with the Universal MX 25. I feel underpowered with that engine at times when I get in nasty stuff so anything less would just be a problem waiting to happen.
Jun 8, 2009
64
2 30 Tall Rig Muskegon
You might want to look at Beta Marine engines. I've been considering a repower of my 5411 on my 1983 C30. The 11 HP is generally considered underpowered for the C30. Here's a link: http://www.betamarinenc.com/
They are very familiar with C30's and gave me a couple of options for repower. I know you can reuse parts if you rebuild or buy a rebuilt of the same model, but then those parts are old and subject to failure as well.
Mar 15, 2009
61
Good point on older parts being reused. I replaced the entire drive train from the engine mounts to the castle nut.
I have personally found the 5411 to work just fine for my use, but I am also very new to the game.
I suppose alot of it depends on budget, mine being very limited currently. Damn self employment!
